For 2-up riding on our 1600 Classic.. what settings have you found to be good for you on yours? I set the adjusters to 4 but I have not played with the air pressure. Jeff
vulcanism said:For 2-up riding on our 1600 Classic.. what settings have you found to be good for you on yours? I set the adjusters to 4 but I have not played with the air pressure. Jeff
bluestringer said:
This is about what I was thinkingCruising said:Jeff.....I set mine on 4 also and put 15lbs. in the shocks!! It seems to be riding just like I feel it should! Went on a nice ride this past Sunday around Lake Okeechobee down here in Florida...Just myself on the bike - dropped the pressure to 10lbs. and set the shocks on 2!!!!!!!!!!! Nice smooth ride! Put on a little under 300 miles that day!! It was a PERFECT day for riding......![]()
Brent, I was just googling that and I haven't found anything that says the 04's had air shocks like my 06. Hopefully someone else on here with an 04 can verify that.brent4a said:This might be a stupid question but i just got my 04 1600 Classic a month ago. Does it have air shocks ? I have only seen the outer shocks and if there are air shocks also, i had no idea.
Not sure about that. But, I'm like you, I have no lift available.Babalones said:The owners manual says to raise the back tire before adjusting, but is that absolutely necessary? Right now, I don't have the means to lift the bike.
Thanks
Phil
Brent, I asked another member that has an 04. Here is his reply:brent4a said:This might be a stupid question but i just got my 04 1600 Classic a month ago. Does it have air shocks ? I have only seen the outer shocks and if there are air shocks also, i had no idea.
