Setting the Power Commander for altitude
1 reading
886 views 2 replies 3 participants last post by  ophidia
#1 ·
When you take the bike up to the mountains where the air is a little thinner, would it be worth running an adjusted map?
The bike is set for 500 feet. I have not taken it up to the mountains of New Mexico or Colorado yet. I can only imagine that a map set for 500 feet will not perform as well as a map set at 6000 feet.
#2 ·
I did not try this, but i think it will work. I think bikes are adjusting in normal hight ( lets say 500 feet) IF you are on 6000 your bike will loose some power with original settings and also with PC. It will work but bike will have a little bit less power.
